Date/Time: Sun, 24 Nov 2024 16:21:05 +0000
Bid Price and Ask Price from delta volume bar
View Count: 1161
[2013-11-19 03:05:24] |
setapakforex - Posts: 10 |
If i choose delta volume bar from chart setting, can i output bid price and ask price to spreadsheet trading system?
[2013-11-19 03:16:57] |
Are you referring to the current bid and ask prices?
[2013-11-19 03:41:43] |
yes. Can i output bid price and ask price in sequence if any to E3, E4, E5 ...without OHLC.
[2013-11-19 17:25:18] |
So you want the bid and ask prices for historical Chart bars as well? Not just the latest prices? Have a look at this page: http://www.sierrachart.com/index.php?l=doc/doc_RecordingModes.php And this page: http://www.sierrachart.com/index.php?l=doc/helpdetails31.html And the current Bid and Ask are outputted to the Spreadsheet in the J column. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
