Date/Time: Fri, 26 Apr 2024 10:22:04 +0000
Several accounts in one control
View Count: 739
[2019-03-20 18:07:49] |
User724388 - Posts: 1 |
Hello, I have such question - I have several Bitmex accounts that would like allow me to trade with their money. They have created API keys for me and I would like to do the next things: connect all the accounts to SierraChart and start trading with them, but question is the next one - is there any options to trade with several accounts in the SierraChart system? If yes - can I open/close positions as a percentage of each of the accounts? For example: 1) first account has 1 xbt 2) second account has 3 xbt 3) third account has 1 xbt and i would like to create order with 1% of each account, so orders will looks like 0,01; 0,03; 0,01. Is there such function in SierraChart system? Thank you |
[2019-03-20 22:39:01] |
No, this is not supported. You would have to install three separate instances of Sierra Chart. One for each account: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
