Date/Time: Sun, 24 Nov 2024 16:26:22 +0000
Compiler Won't Build
View Count: 3306
[2013-11-19 00:38:39]
esMike - Posts: 69
I just installed a fresh copy of SierraChart. Have not used it in a year and a half...
Trying to re-compile my old studies for the new version. The compiler throws this error.
g++.exe:error: CreateProcess: No such file or directory
[2013-11-19 00:55:59]
Can you provide us everything you see in the Build Output window. Copy and paste it here.
[2013-11-19 01:06:15]
esMike - Posts: 69
Just trying a hello world... Compiling the example files... I am using Windows Vista.
-- Starting build of Custom Studies Source files: ExampleCustomStudies.cpp. -- 17:05:33
"C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\ExampleCustomStudies.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\ExampleCustomStudies.dll"
g++.exe: error: CreateProcess: No such file or directory
-- End of Build -- 17:05:34
Date Time Of Last Edit: 2013-11-19 01:07:02
[2013-11-19 01:11:04]
Delete this folder:
After that install the compiler again. There must be some missing files.
[2013-11-19 01:38:20]
esMike - Posts: 69
Reinstalling... It hit a few errors already... Look for the "*** ERROR ***" notifications.
C:\SierraChart\CPPCompiler>cd bin
C:\SierraChart\CPPCompiler\bin>mingw-get update
Updating catalogue: package-list.xml; (item 1 of 1)
Updating catalogue: mingw32-package-list.xml; (item 2 of 3)
Updating catalogue: mingw32-autoconf.xml; (item 3 of 40)
Updating catalogue: mingw32-automake.xml; (item 4 of 40)
Updating catalogue: mingw32-basic-bsdtar.xml; (item 5 of 40)
Updating catalogue: mingw32-binutils.xml; (item 6 of 40)
Updating catalogue: mingw32-bzip2.xml; (item 7 of 40)
Updating catalogue: mingw32-dos2unix.xml; (item 8 of 40)
Updating catalogue: mingw32-expat.xml; (item 9 of 40)
Updating catalogue: mingw32-gcc3.xml; (item 10 of 40)
Updating catalogue: mingw32-gcc4.xml; (item 11 of 40)
Updating catalogue: mingw32-gcc-tools.xml; (item 12 of 40)
Updating catalogue: mingw32-gdb.xml; (item 13 of 40)
Updating catalogue: mingw32-gendef.xml; (item 14 of 40)
Updating catalogue: mingw32-gettext.xml; (item 15 of 40)
Updating catalogue: mingw32-gmp.xml; (item 16 of 40)
Updating catalogue: mingw32-libarchive.xml; (item 17 of 40)
Updating catalogue: mingw32-libiconv.xml; (item 18 of 40)
Updating catalogue: mingw32-libtool.xml; (item 19 of 40)
Updating catalogue: mingw32-lua.xml; (item 20 of 40)
Updating catalogue: mingw32-make.xml; (item 21 of 40)
Updating catalogue: mingw32-mingw-get.xml; (item 22 of 40)
Updating catalogue: mingw32-mingw-utils.xml; (item 23 of 40)
Updating catalogue: mingw32-mgwport.xml; (item 24 of 40)
Updating catalogue: mingw32-mpc.xml; (item 25 of 40)
Updating catalogue: mingw32-mpfr.xml; (item 26 of 40)
Updating catalogue: mingw32-pexports.xml; (item 27 of 40)
Updating catalogue: mingw32-popt.xml; (item 28 of 40)
Updating catalogue: mingw32-pthreads-w32.xml; (item 29 of 40)
Updating catalogue: mingw32-runtime.xml; (item 30 of 40)
Updating catalogue: mingw32-wsl-candidate.xml; (item 31 of 40)
Updating catalogue: mingw32-xz.xml; (item 32 of 40)
Updating catalogue: mingw32-zlib.xml; (item 33 of 40)
Updating catalogue: mingw32-libunistring.xml; (item 34 of 40)
Updating catalogue: mingw32-pdcurses.xml; (item 35 of 40)
Updating catalogue: mingw32-tcltk.xml; (item 36 of 40)
Updating catalogue: mingw32-xerces-c.xml; (item 37 of 40)
Updating catalogue: mingw32-base.xml; (item 38 of 40)
Updating catalogue: mingw32-autotools.xml; (item 39 of 40)
Updating catalogue: msys-package-list.xml; (item 40 of 40)
Updating catalogue: msys-autoconf.xml; (item 41 of 109)
Updating catalogue: msys-autogen.xml; (item 42 of 109)
Updating catalogue: msys-automake.xml; (item 43 of 109)
Updating catalogue: msys-bash.xml; (item 44 of 109)
Updating catalogue: msys-binutils.xml; (item 45 of 109)
Updating catalogue: msys-bison.xml; (item 46 of 109)
Updating catalogue: msys-bzip2.xml; (item 47 of 109)
Updating catalogue: msys-console.xml; (item 48 of 109)
Updating catalogue: msys-core.xml; (item 49 of 109)
Updating catalogue: msys-coreutils.xml; (item 50 of 109)
Updating catalogue: msys-crypt.xml; (item 51 of 109)
Updating catalogue: msys-cvs.xml; (item 52 of 109)
Updating catalogue: msys-cygutils.xml; (item 53 of 109)
Updating catalogue: msys-dash.xml; (item 54 of 109)
Updating catalogue: msys-diffutils.xml; (item 55 of 109)
Updating catalogue: msys-diffstat.xml; (item 56 of 109)
Updating catalogue: msys-dos2unix.xml; (item 57 of 109)
Updating catalogue: msys-expat.xml; (item 58 of 109)
Updating catalogue: msys-file.xml; (item 59 of 109)
Updating catalogue: msys-findutils.xml; (item 60 of 109)
Updating catalogue: msys-flex.xml; (item 61 of 109)
Updating catalogue: msys-gawk.xml; (item 62 of 109)
Updating catalogue: msys-gcc.xml; (item 63 of 109)
Updating catalogue: msys-gdbm.xml; (item 64 of 109)
Updating catalogue: msys-gettext.xml; (item 65 of 109)
Updating catalogue: msys-gmp.xml; (item 66 of 109)
Updating catalogue: msys-grep.xml; (item 67 of 109)
Updating catalogue: msys-groff.xml; (item 68 of 109)
Updating catalogue: msys-guile.xml; (item 69 of 109)
Updating catalogue: msys-gzip.xml; (item 70 of 109)
Updating catalogue: msys-help2man.xml; (item 71 of 109)
Updating catalogue: msys-inetutils.xml; (item 72 of 109)
Updating catalogue: msys-less.xml; (item 73 of 109)
Updating catalogue: msys-libarchive.xml; (item 74 of 109)
Updating catalogue: msys-libiconv.xml; (item 75 of 109)
Updating catalogue: msys-libtool.xml; (item 76 of 109)
Updating catalogue: msys-libxml2.xml; (item 77 of 109)
Updating catalogue: msys-lndir.xml; (item 78 of 109)
Updating catalogue: msys-lpr-enhanced.xml; (item 79 of 109)
Updating catalogue: msys-m4.xml; (item 80 of 109)
Updating catalogue: msys-make.xml; (item 81 of 109)
Updating catalogue: msys-man.xml; (item 82 of 109)
Updating catalogue: msys-minires.xml; (item 83 of 109)
Updating catalogue: msys-mintty.xml; (item 84 of 109)
Updating catalogue: msys-mktemp.xml; (item 85 of 109)
Updating catalogue: msys-openssh.xml; (item 86 of 109)
Updating catalogue: msys-openssl.xml; (item 87 of 109)
Updating catalogue: msys-patch.xml; (item 88 of 109)
Updating catalogue: msys-perl.xml; (item 89 of 109)
Updating catalogue: msys-popt.xml; (item 90 of 109)
Updating catalogue: msys-rebase.xml; (item 91 of 109)
Updating catalogue: msys-regex.xml; (item 92 of 109)
Updating catalogue: msys-rsync.xml; (item 93 of 109)
Updating catalogue: msys-rxvt.xml; (item 94 of 109)
Updating catalogue: msys-sed.xml; (item 95 of 109)
Updating catalogue: msys-tar.xml; (item 96 of 109)
Updating catalogue: msys-termcap.xml; (item 97 of 109)
Updating catalogue: msys-texinfo.xml; (item 98 of 109)
Updating catalogue: msys-unzip.xml; (item 99 of 109)
Updating catalogue: msys-vim.xml; (item 100 of 109)
Updating catalogue: msys-w32api.xml; (item 101 of 109)
Updating catalogue: msys-wget.xml; (item 102 of 109)
Updating catalogue: msys-xz.xml; (item 103 of 109)
Updating catalogue: msys-zip.xml; (item 104 of 109)
Updating catalogue: msys-zlib.xml; (item 105 of 109)
Updating catalogue: msys-mksh.xml; (item 106 of 109)
Updating catalogue: msys-base.xml; (item 107 of 109)
Updating catalogue: mingw-developer-toolkit.xml; (item 108 of 109)
Updating catalogue: msys-system-builder.xml; (item 109 of 109)
C:\SierraChart\CPPCompiler\bin>mingw-get install mingw-get
http://prdownloads.sourceforge.net/mingw/mingw-get-0.6.2-mingw32-beta-20131004-1
-bin.tar.xz?download
260.26 kB / 260.26 kB |================================================| 100%
-gui.tar.xz?download
56.92 kB / 56.92 kB |================================================| 100%
-lic.tar.xz?download
12.07 kB / 12.07 kB |================================================| 100%
install: mingw-get-0.6.2-mingw32-beta-20131004-1-bin.tar.xz
installing mingw-get-0.6.2-mingw32-beta-20131004-1-bin.tar.xz
mingw-get: *** ERROR *** C:\SierraChart\CPPCompiler\/libexec/mingw-get/setup.lua
: extraction failed
: probable package conflict; existing file not overwritten
mingw-get: *** ERROR *** C:\SierraChart\CPPCompiler\/libexec/mingw-get/guistub.e
xe: extraction failed
xe: probable package conflict; existing file not overwritten
mingw-get: *** ERROR *** C:\SierraChart\CPPCompiler\/libexec/mingw-get/lastrites
.exe: extraction failed
.exe: probable package conflict; existing file not overwritten
mingw-get: *** ERROR *** C:\SierraChart\CPPCompiler\/libexec/mingw-get/unlink.js
: extraction failed
mingw-get: *** ERROR *** C:\SierraChart\CPPCompiler\/libexec/mingw-get/shlink.js
: extraction failed
mingw-get: *** ERROR *** C:\SierraChart\CPPCompiler\/var/lib/mingw-get/data/defa
ults.xml: extraction failed
ults.xml: probable package conflict; existing file not overwritten
running post-install hooks for mingw-get-bin
install: mingw-get-0.6.2-mingw32-beta-20131004-1-gui.tar.xz
installing mingw-get-0.6.2-mingw32-beta-20131004-1-gui.tar.xz
install: mingw-get-0.6.2-mingw32-beta-20131004-1-lic.tar.xz
installing mingw-get-0.6.2-mingw32-beta-20131004-1-lic.tar.xz
C:\SierraChart\CPPCompiler\bin>mingw-get install gcc
http://prdownloads.sourceforge.net/mingw/gcc-core-4.8.1-4-mingw32-lic.tar.lzma?d
ownload
22.70 kB / 22.70 kB |================================================| 100%
http://prdownloads.sourceforge.net/mingw/gmp-5.1.2-1-mingw32-dll.tar.lzma?downlo
ad
239.75 kB / 239.75 kB |================================================| 100%
http://prdownloads.sourceforge.net/mingw/mpfr-3.1.2-2-mingw32-dll.tar.lzma?downl
oad
160.33 kB / 160.33 kB |================================================| 100%
http://prdownloads.sourceforge.net/mingw/mpc-1.0.1-2-mingw32-dll.tar.lzma?downlo
ad
47.79 kB / 47.79 kB |================================================| 100%
http://prdownloads.sourceforge.net/mingw/pthreads-w32-2.9.1-1-mingw32-dll.tar.lz
ma?download
48.31 kB / 48.31 kB |================================================| 100%
http://prdownloads.sourceforge.net/mingw/gcc-core-4.8.1-4-mingw32-dll.tar.lzma?d
ownload
227.73 kB / 227.73 kB |================================================| 100%
http://prdownloads.sourceforge.net/mingw/zlib-1.2.8-1-mingw32-dll.tar.lzma?downl
oad
57.98 kB / 57.98 kB |================================================| 100%
http://prdownloads.sourceforge.net/mingw/binutils-2.23.2-1-mingw32-dev.tar.lzma?
download
1.28 MB / 1.28 MB |================================================| 100%
http://prdownloads.sourceforge.net/mingw/mingwrt-4.0.3-1-mingw32-dll.tar.lzma?do
wnload
12.79 kB / 12.79 kB |================================================| 100%
http://prdownloads.sourceforge.net/mingw/w32api-4.0.3-1-mingw32-dev.tar.lzma?dow
nload
2.21 MB / 2.21 MB |================================================| 100%
http://prdownloads.sourceforge.net/mingw/mingwrt-4.0.3-1-mingw32-dev.tar.lzma?do
wnload
686.10 kB / 686.10 kB |================================================| 100%
http://prdownloads.sourceforge.net/mingw/binutils-2.23.2-1-mingw32-bin.tar.lzma?
download
22.78 MB / 41.91 MB |========================== | 54%
[2013-11-19 13:57:03]
esMike - Posts: 69
Gave up on it... Tried both laptop and PC a couple times. Vista Ultimate doesn't work it seems.
I then took a few hours to get Visual C++ working. I had to workaround a few different errors to get it working, but all is well now!
Lesson Learned: Update to Windows 7...
