Date/Time: Wed, 01 May 2024 06:21:59 +0000
[Locked] - New High-Performance Trade Activity Log - Version 1885
View Count: 10869
[2019-10-28 07:02:14] |
User234172 - Posts: 44 |
Trade activity will only show P/L values for (C), it will not show any values for (t) or (T) or (p) regardless of the settings chosen.
Date Time Of Last Edit: 2019-10-28 07:28:38
[2019-10-29 06:16:34] |
This is explained here: Trade Activity Log: Profit/Loss (P/L) Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-08 16:09:20] |
User237090 - Posts: 14 |
Hi Sierra Charts, This is a simple yes or no, Is it possible to "customize" the Trade Activity Log.. I've searched global settings extensively and all the window and headings on the log itself without finding any heading or graphics menus for said Trade Activity Log. I may have missed something. The problem with keeping the log as is with all the headings/data is that if I want to print the trades from notepad, the data I want to study isn't there - only the first columns are printed. So, if you could point me to a method to select which columns I want to keep I'd be grateful.. cheers, |
[2020-09-08 16:23:44] |
Ed C. - Posts: 98 |
The answer to your question is "no", and using notepad to print your trades is a very poor solution. Instead, select "Copy All" from the Edit menu, then paste into Excel. Everyting will be there, and you can delete the columns you don't want to see.
[2020-09-08 17:20:49] |
Yes, post #53 makes sense.
[2020-09-08 20:38:40] |
Hmm, yes duly noted.... Just was hoping there was a way to do this without deleting 18 columns every day. Thanks for the quick response - it was appreciated. regards, |
