Date/Time: Wed, 08 May 2024 18:51:22 +0000
Volume format used in Trade Volume Trigger Stop forces bond format volume
View Count: 664
[2019-03-20 14:28:17] |
IconBob - Posts: 61 |
I can't enter a volume such as 50 I'm forced to choose from a drop-down of bond values. See attached.
Bond Volume Format Problem 2019-03-20_10-20-01.jpg / V - Attached On 2019-03-20 14:23:14 UTC - Size: 331.83 KB - 285 views |
[2019-03-21 05:50:08] |
We will get this resolved in the next release.
[2019-03-22 20:00:32] |
The format corrected but still can't enter volume see attach
Bond Volume Format Problem 2019-03-22_15-56-44.jpg / V - Attached On 2019-03-22 19:59:14 UTC - Size: 69.18 KB - 300 views |
[2019-03-22 20:13:04] |
Do you mean the drop down list is empty? It will be empty because that is not going to be automatically filled.
[2019-03-22 22:21:02] |
Sorry, I should have been more specific. I can’t change or enter a different number. It’s locked at 50.
[2019-03-22 23:16:07] |
We see no problem changing that quantity. So if you select the text, 50, and you type over it it does not change?
[2019-03-23 00:43:35] |
It works now but didn't earlier. I did restarts for other reasons perhaps that did it or it was operator error. I'm good to go.
[2019-03-23 00:48:37] |
Ok if there is any odd behavior it is going to be most likely related to the Microsoft list control itself . Just make sure the drop list is not dropped down and select the text and then overwrite it.
