Date/Time: Thu, 25 Apr 2024 17:34:54 +0000
SC installation over proxy
View Count: 1245
[2019-03-20 06:24:32] |
chuka - Posts: 4 |
Hello. I've tried to install SC over proxy, but keep failing. Please help. Thank you Installer Log: Installer version: 9 | 2019-03-20 02:22:05 Using proxy server settings. Address: 19.12.2.40. Port: 83 | 2019-03-20 02:22:29 HTTP Request: https://www.sierrachart.com/API.php?Service=GetCurrentVersionNumber&Version=9 | 2019-03-20 02:22:29 HTTPS connection ID:1 to 19.12.2.40:83 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-03-20 02:22:29 HTTPS connection ID:1 to 19.12.2.40:83 for request ID:1 (1) | Connecting to IP: 19.12.2.40. | 2019-03-20 02:22:29 HTTPS connection ID:1 to 19.12.2.40:83 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-03-20 02:22:29 Download of https://www.sierrachart.com/API.php?Service=GetCurrentVersionNumber&Version=9 did not complete. Status: The connection was closed before a valid response was received. | 2019-03-20 02:22:29 HTTPS connection ID:1 to 19.12.2.40:83 for request ID:1 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-03-20 02:22:29 HTTPS connection ID:1 to 19.12.2.40:83 for request ID:1 (1) | Closed. | 2019-03-20 02:22:29 HTTP Request: https://www.sierrachart.com/API.php?Service=GetCurrentVersionNumber&Version=9 | 2019-03-20 02:22:34 HTTPS connection ID:2 to 19.12.2.40:83 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2019-03-20 02:22:34 HTTPS connection ID:2 to 19.12.2.40:83 for request ID:2 (1) | Connecting to IP: 19.12.2.40. | 2019-03-20 02:22:34 HTTPS connection ID:2 to 19.12.2.40:83 for request ID:2 (1) | Socket gracefully closed by remote side. | 2019-03-20 02:22:34 Download of https://www.sierrachart.com/API.php?Service=GetCurrentVersionNumber&Version=9 did not complete. Status: The connection was closed before a valid response was received. | 2019-03-20 02:22:34 HTTPS connection ID:2 to 19.12.2.40:83 for request ID:2 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-03-20 02:22:34 HTTPS connection ID:2 to 19.12.2.40:83 for request ID:2 (1) | Closed. | 2019-03-20 02:22:34 HTTP Request: https://www.sierrachart.com/API.php?Service=GetCurrentVersionNumber&Version=9 | 2019-03-20 02:22:39 HTTPS connection ID:3 to 19.12.2.40:83 for request ID:3 (1) | Creating socket. Using TLS 1.2. | 2019-03-20 02:22:39 HTTPS connection ID:3 to 19.12.2.40:83 for request ID:3 (1) | Connecting to IP: 19.12.2.40. | 2019-03-20 02:22:39 HTTPS connection ID:3 to 19.12.2.40:83 for request ID:3 (1) | Socket gracefully closed by remote side. | 2019-03-20 02:22:39 Download of https://www.sierrachart.com/API.php?Service=GetCurrentVersionNumber&Version=9 did not complete. Status: The connection was closed before a valid response was received. | 2019-03-20 02:22:39 HTTPS connection ID:3 to 19.12.2.40:83 for request ID:3 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-03-20 02:22:39 HTTPS connection ID:3 to 19.12.2.40:83 for request ID:3 (1) | Closed. | 2019-03-20 02:22:39 Maximum number of retries encountered. Refer to log. Download canceled. | 2019-03-20 02:22:40 |
[2019-03-20 20:40:32] |
Do you know if that proxy server supports TLS? Or is it a nonsecure proxy?
[2019-03-20 21:19:59] |
chuka - Posts: 4 |
Yes, it supports TLS. Thank you |
[2019-03-21 05:43:56] |
From our side we do not know what the problem is. We can just see that the remote side is closing the connection. This is all we can see.
