Date/Time: Thu, 30 Jan 2025 08:26:11 +0000
My Data Feed to slow ...
View Count: 967
[2019-03-19 23:41:25]
User105662 - Posts: 4
Hi I downloaded the current version in Sierra Chart and the problem is the Data Feed instead of going fast as always is going very slow ... so is not working at the speed should do .... what can I do ? Hopefully you can help ... before I downloaded the current version everything was working fine .... Thank you Luis S.
[2019-03-20 00:48:34]
Are you using Transact or CQG for the backend trading service? Or if it is another one do you know which one?
[2019-03-20 02:29:18]
Is transact my platform .... Im having problem with the Data Feed since I downloaded the current version ... how can I make it work ... is way to slow and is not working but it says is connected .
Date Time Of Last Edit: 2019-03-20 03:23:15
[2019-03-20 04:00:53]
You need to follow the Transact set up instructions here:
https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions
You have Sierra Chart set to the wrong Global Settings >> Data/Trade Service Settings >> Service.
Date Time Of Last Edit: 2019-03-20 13:27:57
