Date/Time: Sun, 24 Nov 2024 16:53:21 +0000
Number Bars, text display
View Count: 1126
[2013-11-18 22:18:06] |
toews&kane - Posts: 209 |
Is there a way to display the delta (of each number bar?
Date Time Of Last Edit: 2013-11-19 18:20:12
[2013-11-19 18:20:22] |
bump
[2013-11-20 00:16:36] |
We assume by "Delta" that you mean the difference between Ask Volume and Bid Volume for each bar? If so, then you need to use the Bid Volume versus Ask Volume study. It is documented here: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#BidVolumeAskVolumeStudy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
