Date/Time: Sun, 24 Nov 2024 16:43:59 +0000
Jaromir Svoboda DF connection to TWS IB
View Count: 1408
[2013-11-18 19:03:24] |
Jaromir SVOBODA - Posts: 1 |
Hallo, check my account pls. From 23.10.2013 after one day drop out of payment I can not to connect to my datafeed IB. All settings (TWS, API, GS )seems OK. It is my first trouble a few years after... Thank You for help. Jaromir Svoboda Jaromir.svoboda@yahoo.ca Software version: 996 | 2013-11-18 19:32:13 Current Service Package: 1 | 2013-11-18 19:32:13 Usage end date: 2014-01-01 | 2013-11-18 19:32:13 Active service: Interactive Brokers | 2013-11-18 19:32:13 Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2013-11-18 19:32:13 2013-11-18 19:32:13 Local computer clock time | 2013-11-18 19:32:13 2013-11-18 18:32:13 GMT time | 2013-11-18 19:32:13 2013-11-18 19:32:13 Time zone adjusted time | 2013-11-18 19:32:13 Time difference to server time: 1 seconds. | 2013-11-18 19:32:13 Program path: C:\SierraChart\ | 2013-11-18 19:32:13 Data Files path: C:\SierraChart\Data\ | 2013-11-18 19:32:13 OS Version Number: 6.1 | 2013-11-18 19:32:13 Connecting to IB data and trade server: 127.0.0.1. Port 7496. | 2013-11-18 19:32:21 Error connecting socket: Windows error code 10060: Pokus o připojení selhal, protože připojená strana v časovém intervalu řádně neodpověděla, nebo vytvořené připojení selhalo, protože neodpověděl připojený hostitel. | 2013-11-18 19:32:42 Failed to connect to the data and trade server. | 2013-11-18 19:32:42 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2013-11-18 19:32:42 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-18 19:32:42 To prevent further connection attempts, select File >> Disconnect. | 2013-11-18 19:32:42 Disconnected from IB. | 2013-11-18 19:32:42 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-18 19:32:42 File >> Disconnect selected. | 2013-11-18 19:32:43 Disconnected from IB. | 2013-11-18 19:32:43 Connecting to IB data and trade server: 127.0.0.1. Port 7496. | 2013-11-18 19:33:22 File >> Disconnect selected. | 2013-11-18 19:33:33 Failed to connect to the data and trade server. | 2013-11-18 19:33:33 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2013-11-18 19:33:33 Disconnected from IB. | 2013-11-18 19:33:33 Connecting to IB data and trade server: 127.0.0.1. Port 7496. | 2013-11-18 19:52:40 Error connecting socket: Windows error code 10060: Pokus o připojení selhal, protože připojená strana v časovém intervalu řádně neodpověděla, nebo vytvořené připojení selhalo, protože neodpověděl připojený hostitel. | 2013-11-18 19:53:01 Failed to connect to the data and trade server. | 2013-11-18 19:53:01 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2013-11-18 19:53:01 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-18 19:53:01 To prevent further connection attempts, select File >> Disconnect. | 2013-11-18 19:53:01 Disconnected from IB. | 2013-11-18 19:53:01 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-18 19:53:01 File >> Disconnect selected. | 2013-11-18 19:53:02 Disconnected from IB. | 2013-11-18 19:53:02 |
[2013-11-18 20:11:43] |
Could you please follow through the step-by-step instructions at step number 15 here: http://www.sierrachart.com/index.php?l=doc/IB.php#SetupInstructions From what we can tell about the 10060 error code, this looks like it is a firewall on your computer blocking the connection to the Interactive Brokers Trader workstation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
