Date/Time: Thu, 30 Jan 2025 08:27:50 +0000
Backup keyboard shortcut settings
View Count: 1184
[2019-03-19 15:37:52] |
samual sprat - Posts: 343 |
Hi, I'd like to backup my current sierra keyboard shortcuts and then make some changes and test a new layout. I thought I'd just be able to backup the existing KeyboardShortcuts.config file and then make changes then restore KeyboardShortcuts.config when I'm done, but I tried this with a couple of changes and it failed. So when I put back the backup file the changes are not reverted. Am I backing up the correct file? Thanks S |
[2019-03-19 18:16:19] |
You need to make sure Sierra Chart is not running when you copy that file.
