Date/Time: Thu, 30 Jan 2025 08:35:34 +0000
TopStep Trader
View Count: 1288
[2019-03-18 23:55:56]
Grateful55 - Posts: 32
do I need to get my data from you so my account works properly ? I've tried CTS CQG and Rithmic but if yours is the best I will sign back up I love your platform and just want to have an even playing field
[2019-03-19 01:01:20]
No you do not. You can use CTS, CQG or Rithmic. Those will be fine. If you are using Top Step Trader we recommend using Rithmic instead of CTS.
[2019-03-19 02:45:13]
I must be missing something cause I’ve had them try to hook it up as well as myself but neither of us have had any success. My CQG through AMP is working fine
Date Time Of Last Edit: 2019-03-19 22:45:00
[2019-03-20 13:47:06]
Make sure your current telephone number is set here:
https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo
When that is done let us know and we will call and use remote assistance to look into this.
[2019-03-20 13:49:56]
It is
[2019-03-20 13:50:19]
K thank you
[2019-03-20 14:23:03]
User has been called and another instance of Sierra Chart has been set up to use CTS. We cleared the Intraday File Update List which had a lot of invalid symbols which was causing delays with historical data downloading.
[2019-03-20 16:00:21]
Thanks again it’s running great :)
