Date/Time: Fri, 31 Jan 2025 03:14:07 +0000
Open GL and Utilizing the GPU
View Count: 2093
[2019-03-18 18:35:27] |
LucentTrader - Posts: 35 |
Regarding the work in implementing Open GL is there an ongoing effort to add support for utilizing a GPU on an add-in card such as an NVidia?
[2019-03-18 19:17:30] |
Well certainly the processing occurs on the GPU when OpenGL is going to be used. How that is exactly managed if there are multiple GPUs would be depend upon how the drivers are handling that. This is not something that Sierra Chart would control.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-18 19:17:49
[2019-04-07 21:41:05] |
samual sprat - Posts: 343 |
Any news on the opengl release? Think it's supposed to be due around now
[2019-04-08 04:21:35] |
This is still not ready for release. And there is never a due date for anything. We can only give an expectation of when something might be available and often we are wrong about that.
