Date/Time: Fri, 22 Nov 2024 11:15:14 +0000
Trade Activity Log Sub-Instance
View Count: 1008
[2019-03-18 16:22:41] |
007700 - Posts: 43 |
As each New Instances has its own Trade Activity Log And as each would have its own symbol Is it possible to combine multiple sub-instances into the main SC Chart Trade Activity Log for a P/L Total of all instances combined |
[2019-03-18 16:58:53] |
Any trading from a sub instance is going to be added to the main instance Trade Activity Log. So this is already the case. If you are referring to the Trade Stats for Charts tab of the Trade Activity Log that will only show the charts and Trading DOMs from that instance only. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-18 17:23:05] |
Under the Main Chart Trade Activity Log (*Trades) I only get the trades made in the main chart no sub-instances trades shown Is there something I need the enable for it to work....? |
[2019-03-18 17:49:18] |
Make sure the sub instances are not in Trade Simulation Mode: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-18 20:09:35] |
Not sure if im understanding this correctly At this point all chartbooks (main & sub-instance is in "Trade Sim Mode" as i have not tried live want to make sure it's working properly If sub Instance is in "Live Mode" and main is in "Sim Mode" does the sub-instance trade go through as a "Live Trade".......? Was trying to view Trade Activity Log with all settings on "Sim Mode" |
[2019-03-18 21:23:55] |
Your description confirms why you do not see the sub instance trade activity in the main instance. If sub Instance is in "Live Mode" and main is in "Sim Mode" does the sub-instance trade go through as a "Live Trade".......? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-18 21:59:13] |
I guess what has me confused is This is what appears in the list Main Chart (Sim1)---- Trade Sims Mode checked Sub-Instance (Live "Account number") ------ Trade Sims Mode unchecked Sub-Instance (Live "Account number") ------ Trade Sims Mode unchecked So with this setting, all trade activity would appear in main chart as "Sim1".......? If this is true then when main chart set to live mode all sub-instance would then be live......? |
[2019-03-18 22:15:57] |
Update to the current version of Sierra Chart: Software Download: Fast Update Sub-Instance (Live "Account number") ------ Trade Sims Mode unchecked Sub-Instance (Live "Account number") ------ Trade Sims Mode unchecked There are some versions, where the orders would still be processed using the non-simulated account identifier, but they would still be simulated. In the current versions they get rejected as they should be. If this is true then when main chart set to live mode all sub-instance would then be live......? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-18 23:08:51
[2019-03-18 22:56:04] |
This is the message i get when attempting entry on sub-instance in live mode does not enter trade with BuyMkt order CQG WebAPI order update (Order reject). Info: Non-simulated Trade Account (V5445) cannot be used with Trade Simulation Mode. Internal Order ID: 766. Service Order ID: (none). Symbol: F.US.EPM19 | 2019-03-18 18:51:07 * |
[2019-03-18 23:07:40] |
Yes that does make sense. Refer to this section and the section below: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Simulated Trading in a Sub Instance All of this is very well documented. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-18 23:08:00
[2024-10-11 08:11:14] |
Piotr Grzegorzek - Posts: 21 |
I have three Instances. The Trade Activity Log for the main Instance shows only trades from the main Instance. Trade Activity Log for other instances does not open (Trade >> Trade Activity Log). All Instances are in Sim Mode. |
[2024-10-11 14:27:51] |
John - SC Support - Posts: 36203 |
Are these instances sub-instances started with "File >> New Instance" or are they separate installations of Sierra Chart? With regards to the Trade Activity Log not opening, this is not due to sub-instances. This is a problem where the Trade Activity Log window is opening off-screen for some reason. Select "Window >> Reset Windows" in order to reset the position of the Trade Activity Window (along with other windows) so you can view it again. Refer to the following: Window, CB and CW Menus: Reset Windows (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
