Date/Time: Thu, 28 Mar 2024 19:19:24 +0000
CFFEX CSI 300 Index Futures Subscription
View Count: 2030
[2019-03-18 06:51:18] |
User14410 - Posts: 38 |
May I ask is that possible for me to subsribe to CFFEX CSI 300 Index futures? As I could not find the data provided in my current Advnaced 5 package. Thank you very much.
[2019-03-18 16:45:36] |
On what exchange does does this futures market trade?
[2019-03-18 20:37:31] |
The exchange is cffex. Thank you. Also, may I ask is there availability for long term (e.g. half an year ) market depth historical data for other futures?
[2019-03-19 15:10:45] |
John - SC Support - Posts: 30443 |
Ok we understand now, this is the China financial futures exchange. That exchange is not supported unless it happens to be by Interactive Brokers: Interactive Brokers Trading Service Historical market depth data is not yet available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-19 16:20:42] |
Thank you very much. So if I use IB plus sierra chart and turn on the market depth function, could I get the CSI 300 index futures live market depth real tick data and then export them out in csv format? Also, could I do the same thing on Hang Seng Index futures (HKEX) ? Thank you very much. |
[2019-03-19 23:10:15] |
The simple answer to this is just no. The same answer without Hong Kong futures data. Check back with us in about three months for Hong Kong futures data, we may have that available. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-20 13:38:18] |
But I saw that there is hkex data for us to subsribe at the moment, may I ask how I have to wait for around 3 months later?
[2019-03-21 05:45:22] |
But since you are in Hong Kong due to an exclusive arrangement for that particular exchange data we have with a trading educator in Hong Kong, we cannot make that data available to you. We hope to be able to offer it though within about 3 months. But that still remains to be seen.
[2019-07-02 07:28:28] |
llk1234 - Posts: 1 |
Would like to know if the exclusive arrangement (in the post above 2019-03-21 05:45:22) with the trading educator in Hong Kong is still effective ?
[2019-07-02 21:49:02] |
It will end August 1, 2019.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-02 21:49:09
[2019-08-03 12:02:40] |
Yes. The Hong Kong futures exchange data is available to everyone now.
