Date/Time: Sun, 20 Sep 2026 06:50:34 +0000
TPO profiles - better access to statistical data
View Count: 7539
| [2020-09-25 12:16:28] |
| User226530 - Posts: 5 |
I have to ask it again, because i can't find it yet in the TPO Study. Are the Ideas from Post #29 implemented yet or do i have to use the chart value for tools to see the rotation factor? like mentioned it would be good to have this in the TPO chart like volume and range for example. Thanks |
| [2020-10-07 05:37:34] |
Yes you can display the Rotation Factor directly on the TPO profiles. See this Input and the following inputs: Time Price Opportunity (TPO) Profile Charts: Show Chart Values On Profile Let us know if anything else is required in this thread. We are restarting our continued development of the TPO profile chart study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-07 05:38:09
| [2020-10-07 08:58:56] |
| User722856 - Posts: 81 |
Dear Sierra, Really glad that you are now working again on TPO charts. Yes, some requirements from this Post are open. Regarding to Post #48, #47,#46 and Post #40. - This feature would be nice and is Open: „Volume Above/Bellow TPO-POC: This displays the volume traded above and below the TPO point of control.“ --> We we want to see the volume above/bellow POC (POC = TPO point of control) --> and not to confuse with the volume above/bellow VPOC (Volume point of control), this is already implemented Thanks Best regards M P.S.: If you need any extra help as a tester let me know. I can help for free… Working in IT... Date Time Of Last Edit: 2020-10-09 14:10:19
| [2020-10-07 10:00:27] |
| traderacefly - Posts: 57 |
"We we want to see the volume above/bellow POC (POC = TPO point of control)" +1 |
| [2020-10-10 00:13:40] |
Regarding post #52 #53, this will be out in the next release.
| [2021-05-15 04:27:14] |
| User139520 - Posts: 28 |
I stumbled upon this post while searching for a way to export TPO historical data in Chart Values to a spreadsheet. I am wondering if this feature has been added to the study library.
| [2021-05-17 13:46:03] |
| John - SC Support - Posts: 47939 |
There has been no changes to this. So you can still get the current TPO information in the spreadsheet, but not the previous ones. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Viewing TPO Profile Text Information For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
