Date/Time: Sun, 02 Mar 2025 03:42:41 +0000
Hide Spreadsheet Tab
View Count: 851
[2019-03-15 12:27:19] |
chart_warrior - Posts: 96 |
Is there a way so hide the ".scss" tab somehow? I don't see a reason for it to be visible unless you need to edit the spreadsheet. It just takes up space along with other tabs. e.g. if you have 4 charts and each has a spreadsheet study you now have 8 tabs open. |
[2019-03-15 18:05:44] |
ForgivingComputers.com - Posts: 1021 |
If they all use the same spreadsheet formulas, they can be different sheets in the same SCSS file. Then only one is needed.
[2019-03-15 18:21:16] |
Yes we recommend what is said in post #2. Simply use the same Spreadsheet for each Spreadsheet study instance and each chart will use a different Sheet within the Spreadsheet window.
[2019-05-27 08:46:51] |
caligola - Posts: 116 |
I have the same question is there a way to hide a Spreadsheet Tab? I have already tryed with Window --> Hide Window but it doesn't work |
