Date/Time: Fri, 31 Jan 2025 00:18:02 +0000
Horizontal Ray Tool - Extend until future intersection stopped working again
View Count: 888
[2019-03-15 09:52:45] |
User132748 - Posts: 159 |
Horizontal Ray Tool - Extend until future intersection stopped working again 1882 build |
[2019-03-15 17:06:12] |
This functionality is still being worked on. It is actually very complex to implement efficiently. It still may be a couple of weeks before we can get back to this.
[2019-04-04 11:32:36] |
User907968 - Posts: 825 |
Hi support, I assume this feature has been looked at again, as it seems to be working in v1894. I notice that the ray lines do not extend in to the fill space any longer, when using price labels this can cause areas of current price action to be obscured. If this is the new functionality of this tool, please would you consider adding an option to align the label to the 'right edge' or 'value scale' similarly to how studies that use extension lines function, or even just an option to place the label in the fill space would work. Thanks. |
[2019-04-05 08:37:24] |
This will be resolved in the next release.
