Date/Time: Sun, 24 Nov 2024 16:56:25 +0000
chart 2 symbols
View Count: 1639
[2013-11-18 11:43:46]
gymjack - Posts: 20
Would like to know how to create a chart of 2 symbols, such as spy:vix or iwm:agg ?
Any assistance apprciated.
[2013-11-19 01:19:40]
Do you want to calculate the Difference or Ratio between them?
[2013-11-19 02:48:01]
gymjack - Posts: 20
want to calculate the ratio.
thanks
jack drucker
[2013-11-19 08:46:32]
Therefore, this can be done by using the Ratio study:
http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s5
[2013-11-19 14:43:07]
Matt654 - Posts: 73
Hi Support has Sierra charts got a symbol for the 10 year bond, I am using SC Forex (FXCM) data feed.
[2013-11-19 22:06:36]
Yes. We recommend using the Sierra Chart Historical Data service:
http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html
It has the US 10 year bond symbol.
You might want to install another copy of Sierra Chart on your system to use with that service:
http://www.sierrachart.com/index.php?l=doc/MultipleServices.html
Date Time Of Last Edit: 2013-11-19 22:07:13
