Date/Time: Thu, 06 Feb 2025 10:08:51 +0000
[Programming Help] - Market depth historical graph - June contract not working the same as March
View Count: 944
[2019-03-12 14:08:26] |
User684068 - Posts: 3 |
Hi, I have attached a chart book called nasdaq although it is actually for the S&P e-mini. I have a problem with the market depth historical graph - tabs in the chartbook 2 and 4. The graph was working fine on the March contract - minimal graphs (even during the new york session - see previous days) showing area's of interest (support and resistance). I rolled over to the new June contract by duplicating this tab and then changing the contract - since then the graph seems to show the entire print (http://www.sierrachart.com/image.php?Image=1552399431597.png) as you would see in the DOM rather than just the area's of interest as the previous chart did (tap 2) http://www.sierrachart.com/image.php?Image=1552399548228.png I have compared the settings on each of the studies and they appear to be the same - hence the duplicated chart - however they are definately not working the same. If you could help in any way that would really be appreciated. Kind regards, Tom |
nasdaq.Cht - Attached On 2019-03-12 13:55:28 UTC - Size: 1.15 MB - 399 views |
[2019-03-25 20:02:57] |
User138602 - Posts: 169 |
Sry to take your thread hostage: I just discovered sc's heatmap and i am currious: When rolling over to the next contract do i get the orderflow from the previous contract shown or do i have to start to collect the orderbook flow some time prior to the rollover to avoid an empty chart? |
