Date/Time: Sun, 24 Nov 2024 16:53:10 +0000
Is there an option to change the color of the order connecting lines?
View Count: 1179
[2013-11-18 04:16:32] |
reggytrades - Posts: 29 |
Right now, they are the same color as my grid color. It is hard to see. Especially if I have more than one order active. That is, the entry, target, stop. Feature request: The integration of the Risk/Reward study into the DOM. I find features of the Risk/Reward study make placing multiple orders on multiple charts easy to follow. Hope you all agree. See attached. BTW, thanks for all the great work and continued development. Cheers, Reggy Date Time Of Last Edit: 2013-11-18 06:12:55
EURJPY 0.03 rng #1 41596.253.png / V - Attached On 2013-11-18 06:12:05 UTC - Size: 89.67 KB - 405 views |
[2013-11-18 16:45:40] |
Yes. Refer to the last step in the instructions in this section here: https://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#DisplayingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-18 19:33:01] |
Is there a difference between the "order association lines" and the "chart order entry/exit connection lines"? I have found that the lines I'm needing to change color and style for can only be changed by changing the grid color. Then the problem remains how to visually distinguish between multiple scalps/ swing orders against a forest of the same color? This is very difficult for someone that does manual trading and requires a quick visual status of their orders. There was a prior response by support indicating that the grid is the only way to control the color change. Please see attached chart w/lines highlighted by the yellow arrows and the small red triangle. Note that the "entry/exit connecting lines" menu option on Graphic Settings is black/4pts while the "order association lines" are agua/1pt. While I believe SC has close to state of the art functions for automated trading, I'm hoping SC engineers will consider upgrading the color options for manual traders. Please consider it. |
[2013-11-20 06:59:52] |
We misunderstood. We thought you were referring to the Order Fills Connecting lines. We will add separate color and style settings for the Order Association Lines. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
