Date/Time: Sun, 04 Oct 2026 03:25:44 +0000
BitMEX Open Interest Data
View Count: 5481
| [2019-03-12 07:52:15] |
| D1xVol - Posts: 3 |
Hi, It seems that Sierra Chart's default OI study does not pull correct values for OI data. Could this be remedied in future versions? Many thanks. |
| [2019-03-12 17:25:54] |
Sierra Chart does not support BitMex open interest data. This will not be supported.
| [2019-05-29 20:40:32] |
| User364630 - Posts: 13 |
Dear support What means "not supported"? The data is available and will be showed in Tool Value Window. Date, Open, High, Low, Close, Volume, OpenInterest 2017/03/21, 1076.6999512, 1120.0000000, 1066.6700439, 1111.7800293, 31752302, 18526 2017/03/22, 1112.4499512, 1112.8199463, 989.0000000, 1036.3100586, 64913124, 31079 2017/03/23, 1037.3800049, 1052.6199951, 1015.4299927, 1031.0100098, 20109359, 12845 2017/03/24, 1030.0200195, 1032.9399414, 921.2000122, 936.0000000, 64951798, 37561 So why can we not use it in studies? Is an work around available? thx d. |
| [2019-05-30 04:59:33] |
Most likely those last numbers are the number of trades for the time period of the data.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-30 04:59:42
| [2019-08-06 08:27:35] |
| mountainwolf - Posts: 37 |
The man-doc says -- Open Interest is only available for Historical Daily data type of charts, not Intraday charts. Why there's no Open Interest study for intraday charts? It is the most essential piece of information for trading fut-markets or this much mysterious inverse-perp-swap contract for that matter; only next to the price ticker itself. The realtime OI data-stream is available via var APIs; is it not -- Deribit provides three different interfaces to access the API: JSON-RPC over Websocket -- JSON-RPC over HTTP -- FIX (Financial Information eXchange). # curl https://www.deribit.com/api/v2/public/ticker?instrument_name=BTC-PERPETUAL {"jsonrpc":"2.0","result":{"timestamp":1565078585476,"stats":
{"volume":32755.25421432,"low":11585.0,"high":12331.0},"state": "open","settlement_price":12213.51,"open_interest":86988241, Date Time Of Last Edit: 2019-08-06 08:36:45
