Date/Time: Wed, 29 Jan 2025 06:01:07 +0000
CQG WEBAPI activation request
View Count: 603
[2019-03-12 02:01:27] |
User614908 - Posts: 1 |
Hello I need CQG WEBAPI enabled for my trial of CQG with AMP Futures it currently says not enabled.
[2019-03-12 02:23:14] |
Sierra Chart - Max - Posts: 5780 |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support |
