Date/Time: Wed, 29 Jan 2025 06:03:30 +0000
Unwanted chart duplication
View Count: 653
[2019-03-11 08:19:01] |
User179926 - Posts: 2 |
Every time that a chart is modified, either by editing studies, or by changing chart attributes, upon saving and completing modifications a new chart appears; titled "1 trade". For example and ESM19 1 min chart is open, a study is modified and saved. Upon clicking ok, a new "1 trade" chart appears. If a do 5 additional changes to the original chart, 5 new "1 trade" charts appear. Have no idea why this is happening, Except that it started after I upgraded to the latest version of SC last week. |
[2019-03-11 14:53:24] |
John - SC Support - Posts: 37538 |
This must be caused by a custom study you are using. Restart Sierra Chart and enable Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode Otherwise, Sierra Chart does not have any feature to be opening charts automatically in this kind of case. It could only be done by a custom study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-11 17:50:12
