Date/Time: Mon, 21 Apr 2025 23:30:19 +0000
Export data report
View Count: 754
[2019-03-10 18:20:57]
User132871 - Posts: 14
Whenever I export trade activity the time is incorrect in the export. The time on the platform is correct through. Please advise.
[2019-03-10 20:20:54]
The time is UTC. This is explained in detail here:
Trade Activity Log: Importing and Exporting Data (Importing and Exporting Data)
The documentation explains what to do if you want to see the actual time already displayed.
Date Time Of Last Edit: 2019-03-12 16:51:49
[2019-03-12 14:28:48]
My question is regarding the export. In the platform it's in EST but when I export the report a different time come out. I don't see info about this in the link you sent. Do you understand the issue I am having?
[2019-03-12 16:51:25]
The documentation says this:
The Date-Times of the exported order fills will be in the UTC time zone. If you do not want to import this data, and you want the Date-Times in the global time zone setting you have Sierra Chart set to, then instead use Saving to a Text File.
[2025-02-12 10:34:36]
Yeager - Posts: 132
Is there any documentation on the alternative export options?
-Export to CME audit log CME v3.
-Generate CME audit trails from trade activity
Reason I ask is that I am running an audit for a fund that want stats out of a strategy.
Many thanks
[2025-02-12 16:40:45]
Sierra_Chart Engineering - Posts: 19290
Those commands are not available for Sierra Chart users to use. They are for internal use.
