Date/Time: Thu, 13 Feb 2025 10:47:49 +0000
Combine trades into original summary trade
View Count: 2271
[2019-03-09 21:26:05] |
User457141 - Posts: 7 |
What Is the equivalent feature for below from Investors RT in sierra charts? https://www.linnsoft.com/features/consolidated-tape I am seeing something called combine trades into original summary trade in Chart Settings , is this equivalent to the Inverstors/RT Consolidated Tape feature? Please let me know. |
[2019-03-09 22:57:31] |
Yes that is the equivalent option and it requires the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-09 23:14:19] |
Thanks for the update, I have CQG Trading account with CME data, Can you provide trail for Sierra Chart Exchange Data Feed to my account? |
[2019-03-12 01:46:56] |
We can see that you already activated the data feed. So you are all set. Let us know if you need further help.
[2020-12-04 16:47:28] |
User777961 - Posts: 1 |
Hello, do you know if Combine Trades into Original Summary works with CQG data feed? Best regards, Blazej
[2020-12-04 17:02:04] |
John - SC Support - Posts: 37916 |
Combine Trades into Original Summary Trade only works with the Real-Time Data Feeds From Sierra Chart. It does not work with any other data feed (including CQG).
[2020-12-05 11:11:46] |
You need to use the Denali Exchange Data Feed for this: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
