Date/Time: Wed, 29 Jan 2025 06:05:25 +0000
32 v 64 bit question
View Count: 887
[2019-03-08 08:14:42] |
User360283 - Posts: 506 |
Currently running v 1880 32-bit PC is I7 2GB 64-bit How and should I be using Sierra 64 bit? thanks |
[2019-03-09 15:34:01] |
ForgivingComputers.com - Posts: 992 |
64-bit allows you to use more than 4GB of memory, but if you only have 2 GB installed, you won't see any improvement with 64-bit Sierra Chart unless you add more memory.
Date Time Of Last Edit: 2019-03-09 16:17:47
[2019-03-09 15:47:12] |
Sawtooth - Posts: 4163 |
Software Download: Difference Between 32 and 64-bit Versions
[2019-03-09 23:23:09] |
It is hard to believe your computer only has 2 GB of memory. If that is really true, it needs to be updated to 8-16 GB.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-09 23:24:19
[2019-03-10 09:32:02] |
truths - Posts: 5 |
yea I was surprised that both got installed, most other software I download only downloads one or the other. I am guessing its common to switch between the two? |
