Date/Time: Mon, 27 Jan 2025 19:34:46 +0000
Last trade marker on TPO chart out of sync with price
View Count: 1033
[2019-03-07 16:03:59] |
shaner - Posts: 4 |
Hello, One of my TPO futures charts has the last trade marker out of sync with current price. I still am using ESH19. On problem chart and others. I have 'NONE' selected for continuous rollover. What should I do? http://www.sierrachart.com/image.php?Image=1551973890971.png Thanks |
[2019-03-07 18:09:04] |
Go to Chart >> Chart Settings and remove the Trade and Current Quote Symbol and change the Symbol to the March contract if that is what you want to chart.
