Date/Time: Wed, 29 Jan 2025 06:07:46 +0000
TPO Profile Chart Study
View Count: 743
[2019-03-07 10:28:37]
nicktrader - Posts: 733
With the VbP Study you have the possibility to choose between different Draw Modes. Unfortunately, the "TPO Profile Chart" Study lacks this option.
If you had the possibility to select only lines, you could include this study in a chart and set the lines to "Until Future Intersection".
Currently there is no possibility to set the lines of the TPO to "Until Future Intersection" within a chart or is there a way?
[2019-03-07 17:42:29]
Specifically what lines are you referring to?
[2019-03-08 04:28:06]
VAH/ VAL/ POC and maybe SinglePrints
[2019-03-08 08:54:07]
Pls take a look to the pic. It is a good example.
To see the naked TPO VA Lines in M1 Chart you have to draw a line or rectangle or...
imagenaked VA Lines.png / V - Attached On 2019-03-08 08:53:15 UTC - Size: 47.82 KB - 269 views
[2019-03-08 22:08:02]
This is not supported but longer term we will see about this.
[2019-03-09 11:25:01]
TPO is part of package 5 and I would have assumed it had a higher priority.
