Date/Time: Thu, 26 Sep 2024 23:31:11 +0000
Need Stop-Limit Graphics
View Count: 605
[2019-03-07 02:08:46] |
User116783 - Posts: 84 |
Hello, I exclusively use stop-limits (with a simple bracket order) for order entries. With a long order, I have them colored green; when short, red. However, when I'm short, and the order fills, my buy-stop is also green. If I change it to red, then my long stop-limits will also be red. Long and the short (no pun intended) there is need for separate graphics settings for stop-limits. Hope this makes sense. ZH Date Time Of Last Edit: 2019-03-07 02:11:37
[2019-04-04 22:24:01] |
I am attaching pics of buy orders and sell fills. If you notice for the buy order, the stop limit is colored green. Since it's set to green though, my stop target seen in the sell-fill pic is also green. What I need is a way to turn it red, whilst keeping the stop-limit for buy orders green. So separate graphics for stop-limits, and separate graphics for regular stops. Would this be possible to implement? Thanks, ZH Date Time Of Last Edit: 2019-04-04 22:25:50
buy-order.PNG / V - Attached On 2019-04-04 22:23:25 UTC - Size: 77.38 KB - 208 views sell-fill.PNG / V - Attached On 2019-04-04 22:23:29 UTC - Size: 76.6 KB - 221 views |
