Date/Time: Mon, 27 Jan 2025 19:53:20 +0000
QuoteBoard futures not displaying data
View Count: 609
[2019-03-06 18:16:55] |
MR777 - Posts: 2 |
Hi, Using SC data with trial. QuoteBoard displaying FXCM FX data correctly but nothing on FX futures (data was downloaded). See attached image. |
QuoteBoard.PNG / V - Attached On 2019-03-06 18:13:42 UTC - Size: 23.83 KB - 237 views Attachment Deleted. |
[2019-03-06 23:32:55] |
Refer to this page: Is Historical and Real-time Futures Data Included? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
