Date/Time: Mon, 27 Jan 2025 19:26:34 +0000
Making anothe stock's windows
View Count: 589
[2019-03-06 18:07:56] |
John Ara - Posts: 125 |
I have faced a problem like when building my watchlist in the morning I need to have my diffrent stocks open in sierra whith emoji indicators active on them. Snapshot attached shows I have categorized indicators in 3 diffrent group so I have 3 active windows for each stock. Now, when making anothe stock's windows, I tried 2 ways: 1- I save current file with new stock's name and then in chart settings I find the stock and then after pressing OK, that little rotating thing (in the middle of attached image) shows up. It finally makes me close and reopen it. 2- I tried to go through 'find new symbol' but this way you need to set all graphical parameters again which is impossible at open. Please let me know of a very quick (really needed at open) way to have diffrent stocks open with my 3 set studies running on them. Thank you. |
photo_2019-03-06_12-33-48.jpg / V - Attached On 2019-03-06 18:03:03 UTC - Size: 87.91 KB - 244 views |
[2019-03-07 15:59:57] |
John - SC Support - Posts: 37485 |
Refer to the following information for the Associated Watchlist. This lets you change symbols within a specified group of symbols on the chart: Changing the Symbol of a Chart: Using the Associated Watch List Also note the subsection within the above called Combining the Associated Watch List with Chart Linking, as you will want to set the 3 charts you use to the same Link number and have the Symbol linked between them. Then as you move through the Watchlist, all the charts will update to the same symbol. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
