Date/Time: Wed, 29 Jan 2025 06:11:36 +0000
IB Invalid Time in Force: IOC
View Count: 28512
[2019-03-06 17:44:37] |
User104896 - Posts: 11 |
Hi, I keep receiving this error message: Trading message from IB: Invalid time in force:IOC. Error Code: 10052. ServiceOrderID: 2452. InternalOrderID: 2029552. | 2019-03-06 12:33:03 * Invalid time in force:IOC. Internal Order ID: 2029552. Service Order ID: 2452. Symbol: TD-STK-SMART-CAD | 2019-03-06 12:33:03 * The IOC used to work before I updated the symbol as per IB, using ABX as an example. I've formatted as ABX-STK-SMART-CAD for TSX exchange. Now this error shows up and I don't know how to resolve it. Can you help please? Thanks |
[2019-03-06 17:49:59] |
No we cannot help. You need to ask Interactive Brokers about this.
[2019-03-11 15:58:49] |
For the benefit of other readers, the issue was explained to me by IB. There are certain orders that are only available on certain exchanges. If you follow this link (https://www.interactivebrokers.com/en/index.php?f=594), it will show the Immediate-or-Cancel page for IB, then click on "View Supported Exchanges". If you don't see the exchange you want to trade with on that list, then you cannot use IOC orders. FYI |
