Date/Time: Mon, 27 Jan 2025 19:30:35 +0000
Installation failure - Current version 1857
View Count: 922
[2019-03-06 17:21:58] |
User594504 - Posts: 1 |
This account is via AMP w/ CQG. I have tried updating to 'Current', 'Pre-release', and a specific version (1860), all fail with a failure to find specific files under a TRANSACT sub-folder. I sent one of my logs from the failure to support a earlier this AM. Can someone point me to a solution, please? |
[2019-03-06 23:55:31] |
We are testing this.
[2019-03-07 02:41:03] |
Try again with Help >> Download Prerelease. And do not check the option to install optional files.
