Date/Time: Sun, 24 Nov 2024 12:00:47 +0000
[User Discussion] - Number bars up front colors i can not see numbers
View Count: 680
[2019-03-06 17:16:46]
Hopeman - Posts: 166
Hello the colors cover the numbers!
Is there any kind of combination that does not cover the numbers? !! I'm interested in seeing the colored imbalances plus the bolumen reflected in each bar
Thank you
imageCaptura de pantalla 2019-03-06 a las 18.10.22.png / V - Attached On 2019-03-06 17:15:56 UTC - Size: 102.11 KB - 284 views
imageCaptura de pantalla 2019-03-06 a las 18.10.52.png / V - Attached On 2019-03-06 17:16:04 UTC - Size: 140.73 KB - 267 views
[2024-05-31 19:25:56]
VLiviu - Posts: 223
Opening a very old post which is still a pain in the ass, you must find the right colors in order to have a readable footprint.
An improvement on the Number Bars study would be great, another option to set the background of specific text...
Please!
[2024-05-31 20:19:07]
You can set the font color for the text using the following Input:
Numbers Bars: Default Text Color
You can also use the "Text Coloring Method" to color the text based on some condition, most likely the same one that is used for the background coloring. Then you can use the option for a different set of colors for the text and adjust the text colors to be contrasting to the background colors. Refer to the following:
Numbers Bars: Use Separate Colors for Text Coloring Method
[2024-05-31 21:23:03]
VLiviu - Posts: 223
I know all these methods but won't help you if you do not choose your colours very very wisely otherwise you won't perceive the text colour if the background is colored too.
thanks!
