Date/Time: Mon, 27 Jan 2025 19:44:50 +0000
way to bulk delete quote board disabled alerts ?
View Count: 693
[2019-03-06 16:25:52] |
User902167 - Posts: 31 |
Is there a way to bulk delete alerts that have all ready hit other than only way i know of by right clicking on each one and deleting ? this is a pain in butt when you have a dozen or more to do . These are mixed in with other alerts that are still enabled and haven't gone off. These would be for the Symbol Alerts Tab.
Date Time Of Last Edit: 2019-03-06 16:28:13
[2019-03-06 23:26:40] |
We will add a Delete Completed Alerts command to the Edit menu of the Alerts Manager.
[2019-03-07 02:50:58] |
oh great !! thank you, i have alerts through out the day going off and to have to delete them one by one is not fun.
[2019-03-07 06:56:00] |
i just installed the latest version of sierra and the bulk delete works great !! sooooo much nicer now. Thank you for the quick fix.
[2019-03-07 07:37:33] |
Ok good. We did not even have a chance to test that yet. So glad it works.
