Date/Time: Sun, 24 Nov 2024 15:11:29 +0000
Labels for studies
View Count: 1989
[2013-11-16 20:47:45]
User96105 - Posts: 113
Hi, I've been having some issues with labels. I think this followed an update a month or so ago. For example, with Time Line studies I used to be able to name label the line with vertical alignment "Below", which would show at the top of the chart. I'm sure the Draw Style used to be Bar, but now it reverts to Bar Top, which doesn't have the label options available. Is there another draw style I can use for this?
Also I was going to ask about labels for volume by price peaks/valleys, but I saw somewhere this is in development?
Thanks,
[2013-11-17 00:00:48]
1. We can only refer you to the documentation for Name and Value labels here:
http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#NameValueLabels
Labels should work with any type of Draw Style.
2. We will try to complete development of TPO/Volume Profile Peak and Valley lines soon.
Date Time Of Last Edit: 2013-11-17 00:00:56
[2013-11-17 17:27:10]
Thanks, but as far as I can see this is not working correctly for the Time Line study which only permits Bar Top/Bar Bottom draw styles. Prior to the upgrade a month or so ago the Time Line study must have permitted other draw styles, as I was able to apply name labels correctly previously.
Currently I'm on version 1043 ~ please check functionality at your end.
[2013-11-17 17:54:41]
..just tried with version 1046 and I'm seeing the same (add new Time Line initially gives Bar type draw style, but once saved it reverts to Bar Top). Thanks
