Date/Time: Mon, 27 Jan 2025 19:29:56 +0000
Compile Error on 32-bit
View Count: 760
[2019-03-05 23:28:33]
ForgivingComputers.com - Posts: 991
This is an error I get with 32-bit compilation (version 1880):
-- Starting remote build of Custom Studies Source files: Contracts_17.cpp. 32-bit -- 17:23:05
Allow time for the server to compile the files and build the DLL.
The remote build did not succeed. Result:
Contracts_17.cpp: In function 'void scsf_TrendIndicators(SCStudyInterfaceRef)':
Contracts_17.cpp:1772:9: error: 'struct s_SCSubgraph_260' has no member named 'StudySummaryCellText'
Trend.StudySummaryCellText = "Trend 1";
Contracts_17.cpp:1778:9: error: 'struct s_SCSubgraph_260' has no member named 'StudySummaryCellText'
Trend.StudySummaryCellText = "Trend 2";
Contracts_17.cpp:1784:9: error: 'struct s_SCSubgraph_260' has no member named 'StudySummaryCellText'
Trend.StudySummaryCellText = "Error";
Contracts_17.cpp:1790:9: error: 'struct s_SCSubgraph_260' has no member named 'StudySummaryCellText'
Trend.StudySummaryCellText = "";
-- End of Build -- 17:23:09
I don't get any errors with 64-bit compiling:
-- Starting remote build of Custom Studies Source files: Contracts_17.cpp. 64-bit -- 17:24:15
The remote build succeeded.
Writing file to: C:\SierraChart\SierraChartTransActMA\Data\Contracts_17_64.dll
-- End of Build -- 17:24:20
[2019-03-05 23:55:20]
That is true. That particular Subgraph member is only available in the 64-bit version.
Date Time Of Last Edit: 2019-03-05 23:55:31
[2019-03-06 03:48:07]
So, are there plans to bring that feature to the 32-bit version?
[2019-03-06 04:16:37]
No definitely not.
[2019-03-06 14:41:54]
This is the first time I have seen differences between the two versions. I have seen nothing in the documentation or release notes about such differences with ACSIL custom studies.
Is there a particular reason why you "definitely" won't support 32- and 64-bit versions the same way with the same ACSIL functionality?
Are there other differences I should know about as a developer of custom studies?
[2019-03-06 17:10:47]
This is a rare exception and really the only case where you will find a difference. The problem is that the SCString size on the 32-bit version is too large and would take up too much space in the Subgraph structure and not allow room for future expansion.
