Date/Time: Mon, 27 Jan 2025 19:25:56 +0000
Moving from TransacT to Ironbeam
View Count: 1651
[2019-03-05 20:36:14]
User283066 - Posts: 3
I hope this additional information can help you with my issue that I highlighted in an earlier email, below?
I am trying to sync a pre-existing 'TransactAT' Sierra chart with 'cqg/ironbeam'.
Regards,
Drew
Sent: March 5, 2019 2:42 PM
To: Sierra Chart Support
Cc: AtEase HMS
Subject: Re: Sierra Chart Login Information
My name is Drew Schedler.
My Sierra accout name is dschedler.
I am having issues opening my sierra charts.
I currently have TransactAT charting downloaded on my laptop because I was using TransactAT for a free demo.
Now I am signed on with Cannon Futures to trade through Ironbeam using a CQG data Feed.
Do I need to remove the TransactAT file on my computer, or can I continue using the Sierra program files therein?
If so, is there any way to save and re-apply my chart setting to the new version of Sierra?
In my TransactAT free Sierra Chart trial, I created my own set of charts called "DrewsCustom.cht".
I am hoping I can retrieve this configuration?
I have tried to download sierra anew from the sierra website but receive an error message -- failed to create folder -- as follows:
Any help on this matter is appreciated.
Regards,
Drew
PS I left the screenshots out as instructed
[2019-03-06 17:21:20]
We will take this one step at a time. In regards to this:
Install Sierra Chart using this installer:
https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe
If there is a problem with the installation, provide the installer log:
Software Download: Providing Installer Log to Support
Here is the documentation to copy your Chartbook's and other files from one installation of Sierra Chart to another:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Updating Existing Installation of Sierra Chart with Files and Settings from Another Installation
Date Time Of Last Edit: 2019-03-06 17:21:52
[2019-03-06 17:44:06]
I have tried downloading again without success.
I sent the installer logfile as instructed in Step 2 above.
Access Denied is what I am searching for on the support board now.
Can you please supply additional info?
Thank you!
Drew
Date Time Of Last Edit: 2019-03-06 18:11:41
[2019-03-06 22:26:41]
I was able execute Sierra chart download successfully.
The issue was with the default destination pathway.
I had to force it to go to my sierra file in a new partition and overwrite it.
Yet, I am still not able to connect.
I am getting locked out with valid credentials.
There are still remnants of TransactAT files present in the download.
Should these be removed?
Thank you,
Drew
[2019-03-06 22:54:08]
Yes.
For help with CQG connection problems, refer to:
CQG Trading Platform Service: Common Error Messages
