Date/Time: Mon, 27 Jan 2025 19:41:09 +0000
Have a problem with connection
View Count: 952
[2019-03-05 20:25:09]
User14921 - Posts: 1
Hi
I have an account in Gain Capital and haven't connected to Sierra Chart.
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2019-03-05 18:13:46
GAIN Capital FIX Trading socket (1) | Creating socket. | 2019-03-05 18:13:46
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.238. | 2019-03-05 18:13:46
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-05 18:13:46
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-05 18:13:46
GAIN Capital FIX Trading socket (1) | Max send buffers used during socket life: 1 | 2019-03-05 18:13:46
GAIN Capital FIX Trading socket (1) | Signaling to core to close socket | 2019-03-05 18:13:46
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2019-03-05 18:13:46
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-03-05 18:13:46
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-05 18:13:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-05 18:13:46
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-05 18:13:46
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-05 18:13:46
GAIN Capital/OEC | Disconnected. | 2019-03-05 18:13:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-05 18:13:46
File >> Disconnect selected. | 2019-03-05 18:13:48
GAIN Capital/OEC | Disconnected. | 2019-03-05 18:13:48
[2019-03-06 17:19:50]
These are the relevant messages:
Refer to:
https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ConnectionProblem
[2019-03-06 17:44:07]
First, if you have not followed all the Setup Instructions for Gain Capital, then be sure to do so by following the instructions here:
https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#SetupInstructions
If the setup is complete per the above instructions, then refer to the following for troubleshooting procedures, particularly the section for All Other Connection Issues:
