Date/Time: Mon, 27 Jan 2025 19:35:10 +0000
Audible Alert Errors
View Count: 687
[2019-03-05 19:24:22] |
User375840 - Posts: 7 |
I have configured HORIZONTAL Lines with an audible alert on my charts. Problem: I get audible alerts that I did NOT configure for No reason. The Alert Manager shows its "generating" on my 5 minute ES chart (#13) with the TIME and PRICE - BUT I did not place a a horizontal line at the price specified. It's as though there's an "invisible" line in the background causing the alert. How do I clear this problem??? Thank You |
[2019-03-06 23:34:13] |
You need to locate that line through the Tools >> Manage Chart Drawings Window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-06 23:34:23
