Date/Time: Mon, 27 Jan 2025 19:38:58 +0000
DTC protocol - supported exchanges/symbols
View Count: 677
[2019-03-05 19:20:40] |
Chad - Posts: 234 |
Is it correct that any datafeed can be accessed from the DTC server (e.g. ICE Europe/LIFFE futures), whether through a 3rd-party source (e.g. Rithmic, iqFeed) or through SC Data?
[2019-03-05 22:38:34] |
Yes.
