Date/Time: Mon, 27 Jan 2025 19:40:34 +0000
price update and session time with custom symbol
View Count: 535
[2019-03-05 00:59:37] |
anouar6869 - Posts: 13 |
I noticed that custom symbol prices do not update after the end of the intraday session time and the evening session is not checked. It's possible to have the same behaviour as with the normal symbols? Thanks |
[2019-03-05 02:39:22] |
The data is still being recorded. Just adjust the Session Times to see the data: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
