Date/Time: Mon, 27 Jan 2025 19:39:40 +0000
Countdown Timer Location Fix v1880
View Count: 583
[2019-03-05 00:11:39]
User14953 - Posts: 238
Just upgraded SC to v 1880 running 32-bit
How is the countdown timer location set to consistently fix the timer readout in place somewhere near the right side of the charts in region 1 and account for analysis study swaps and chart resizing?
Countdown Timer
I followed the directions to move the countdown timer location to where I had it before upgrading. If I swap to a different analysis study and then back, the timer goes back out in left field and requires that I repeat another move action.
[2019-03-05 02:19:15]
Yes that is true. There is no solution to this. If you are removing that study from the chart and adding it again, that is going to be the behavior.
