Date/Time: Mon, 27 Jan 2025 19:26:16 +0000
Order Entry straight from Broker
View Count: 563
[2019-03-04 22:56:12] |
User622702 - Posts: 4 |
Hello, Is it possible to place an order directly from my broker (IB) and not through SC and it still show up on the chart. Thx Nat. |
[2019-03-05 02:29:56] |
Yes. Refer to step 19 here: Interactive Brokers Trading Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
