Date/Time: Mon, 27 Jan 2025 19:47:58 +0000
downloading more historical data than necessary
View Count: 687
[2019-03-04 19:39:57]
User753428 - Posts: 167
in DTS settings, the max historical intraday days to download is set to '8' days.
my chart's Days To Load is set to 3 days and i have volume-based rollover selected for continuous contract.
When i am loading a symbol for the very first time, it downloads only 8 days worth of intraday data, like it's supposed to.
But when I, for example, switch to a different symbol in the chart, and then load the original symbol again, the symbol starts downloading much more intraday data, starting from 11-28-2018.
Because this particular instance is only used for order entry, I have no need for so much intraday data but I'm forced to download much more than I need.
I'm using Rithmic data, if that's relevant.
[2019-03-05 18:33:49]
This is because you are using the continuous futures contract option. You need to disable that.
