Date/Time: Mon, 27 Jan 2025 19:43:02 +0000
Sim works allmost (se question abow) But live trade misses order nr
View Count: 630
[2019-03-04 08:04:22] |
User214624 - Posts: 3 |
Hi! i am almost ready to switch from MT5 to you guys. But when i try to switch from simulation to Live, things happens. Placing orders works fine, but to modify och delete by using internal OrderID nr fales. I can se InternalOrderID and ServiceOrderID in trade activity log. Do i need to use ServiceOrderID? and if so how do i get it when i place an order? Regards Olle |
[2019-03-04 12:00:52] |
Are you referring to modifying an order using ACSIL? You must always use the Internal Order ID. That is the only way to modify an order. To troubleshoot the problem, refer to: Automated Trading From an Advanced Custom Study: Debugging/Troubleshooting Automated Trading Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-04 12:01:59
