Date/Time: Sun, 13 Sep 2026 09:12:44 +0000
error 10061
View Count: 1420
| [2019-03-03 23:32:06] |
| User739935 - Posts: 46 |
I cannot connect I keep getting error code 10061
| [2019-03-04 00:13:16] |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-03-04 00:44:03] |
Reading Internal Order ID file. | 2019-03-03 18:39:51 Reading Trade Orders file. | 2019-03-03 18:39:52 Reading Trade Positions file. | 2019-03-03 18:39:52 Account Balance file. | 2019-03-03 18:39:52 Listening on UDP port 22904. | 2019-03-03 18:39:52 Software version: 1853 32-bit | 2019-03-03 18:39:52 Usage end date: 2019-03-31 | 2019-03-03 18:39:52 Enabled for: Advanced Features. | 2019-03-03 18:39:52 Enabled for: Advanced Features 2. | 2019-03-03 18:39:52 Enabled for: Sierra Chart Historical Data Service. | 2019-03-03 18:39:52 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-03-03 18:39:52 Current selected Data/Trading service: TransAct Trading | 2019-03-03 18:39:52 Chart Update Interval: 500 | 2019-03-03 18:39:52 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-03-03 18:39:52 2019-03-03 18:39:51 Local computer time | 2019-03-03 18:39:52 2019-03-03 23:39:51 Local computer time in UTC | 2019-03-03 18:39:52 2019-03-03 18:39:51 Local computer time in SC Time Zone | 2019-03-03 18:39:52 2019-03-03 23:39:41 Server time in UTC | 2019-03-03 18:39:52 Local computer UTC time and Server UTC time difference: 8 seconds. | 2019-03-03 18:39:52 Program path: C:\SierraChart\ | 2019-03-03 18:39:52 Data Files path: C:\SierraChart\Data\ | 2019-03-03 18:39:52 OS Version Number: 6.2 | 2019-03-03 18:39:52 Locale Setting: C | 2019-03-03 18:39:52 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-03-03 18:39:52 Checking for new symbol settings. Requested symbol settings MD5 for service code transact.trading. Request ID: 1. | 2019-03-03 18:39:52 HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2019-03-03 18:39:52 HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 46.4.97.203. | 2019-03-03 18:39:52 Received 5 login tokens. | 2019-03-03 18:39:52 Symbol settings MD5 received. Request ID: 1. | 2019-03-03 18:39:52 Symbol settings are up-to-date for transact.trading. | 2019-03-03 18:39:52 HTTPS www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2019-03-03 18:39:54 HTTPS www.sierrachart.com:443 (5) | Connecting to IP: 46.4.97.203. | 2019-03-03 18:39:54 HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2019-03-03 18:39:54 HTTPS login.sierrachart.com:443 (1) | Max send buffers used during socket life: 2 | 2019-03-03 18:39:54 HTTPS login.sierrachart.com:443 (1) | Signaling to core to close socket | 2019-03-03 18:39:54 HTTPS login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-03-03 18:39:54 HTTPS login.sierrachart.com:443 (1) | Closed. | 2019-03-03 18:39:54 HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-03-03 18:39:57 HTTPS www.sierrachart.com:443 (2) | Max send buffers used during socket life: 2 | 2019-03-03 18:39:57 HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2019-03-03 18:39:57 HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-03-03 18:39:57 HTTPS www.sierrachart.com:443 (2) | Closed. | 2019-03-03 18:39:57 HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2019-03-03 18:39:57 HTTPS www.sierrachart.com:443 (4) | Max send buffers used during socket life: 2 | 2019-03-03 18:39:57 HTTPS www.sierrachart.com:443 (4) | Signaling to core to close socket | 2019-03-03 18:39:57 HTTPS www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-03-03 18:39:57 HTTPS www.sierrachart.com:443 (4) | Closed. | 2019-03-03 18:39:57 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:39:57 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:39:57 HTTPS www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2019-03-03 18:39:59 HTTPS www.sierrachart.com:443 (5) | Max send buffers used during socket life: 2 | 2019-03-03 18:39:59 HTTPS www.sierrachart.com:443 (5) | Signaling to core to close socket | 2019-03-03 18:39:59 HTTPS www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-03-03 18:39:59 HTTPS www.sierrachart.com:443 (5) | Closed. | 2019-03-03 18:39:59 TransAct Trading | Bridge process is not running! | 2019-03-03 18:39:59 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:39:59 DTC Client socket (1) | Creating socket. | 2019-03-03 18:39:59 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:39:59 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:40:00 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:40:00 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:40:00 DTC Client socket (1) | Closed. | 2019-03-03 18:40:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:40:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:00 TransAct Trading | Disconnected. | 2019-03-03 18:40:00 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:00 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:40:05 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:40:05 TransAct Trading | Bridge process is not running! | 2019-03-03 18:40:07 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:40:07 DTC Client socket (1) | Creating socket. | 2019-03-03 18:40:07 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:40:07 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:40:08 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:40:08 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:40:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:40:08 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:08 DTC Client socket (1) | Closed. | 2019-03-03 18:40:08 TransAct Trading | Disconnected. | 2019-03-03 18:40:08 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:08 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:40:13 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:40:13 TransAct Trading | Bridge process is not running! | 2019-03-03 18:40:15 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:40:15 DTC Client socket (1) | Creating socket. | 2019-03-03 18:40:15 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:40:15 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:40:17 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:40:17 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:40:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:40:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:17 DTC Client socket (1) | Closed. | 2019-03-03 18:40:17 TransAct Trading | Disconnected. | 2019-03-03 18:40:17 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:17 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:40:22 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:40:22 TransAct Trading | Bridge process is not running! | 2019-03-03 18:40:24 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:40:24 DTC Client socket (1) | Creating socket. | 2019-03-03 18:40:24 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:40:24 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:40:25 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:40:25 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:40:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:40:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:25 DTC Client socket (1) | Closed. | 2019-03-03 18:40:25 TransAct Trading | Disconnected. | 2019-03-03 18:40:25 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:25 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:40:30 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:40:30 TransAct Trading | Bridge process is not running! | 2019-03-03 18:40:32 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:40:32 DTC Client socket (1) | Creating socket. | 2019-03-03 18:40:32 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:40:32 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:40:33 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:40:33 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:40:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:40:33 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:33 DTC Client socket (1) | Closed. | 2019-03-03 18:40:33 TransAct Trading | Disconnected. | 2019-03-03 18:40:33 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:33 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:40:38 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:40:38 TransAct Trading | Bridge process is not running! | 2019-03-03 18:40:40 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:40:40 DTC Client socket (1) | Creating socket. | 2019-03-03 18:40:40 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:40:40 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:40:41 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:40:41 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:40:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:40:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:41 DTC Client socket (1) | Closed. | 2019-03-03 18:40:41 TransAct Trading | Disconnected. | 2019-03-03 18:40:41 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:41 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:40:46 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:40:46 TransAct Trading | Bridge process is not running! | 2019-03-03 18:40:48 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:40:48 DTC Client socket (1) | Creating socket. | 2019-03-03 18:40:48 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:40:48 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:40:49 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:40:49 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:40:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:40:49 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:49 DTC Client socket (1) | Closed. | 2019-03-03 18:40:49 TransAct Trading | Disconnected. | 2019-03-03 18:40:49 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:49 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:40:54 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:40:54 TransAct Trading | Bridge process is not running! | 2019-03-03 18:40:56 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:40:56 DTC Client socket (1) | Creating socket. | 2019-03-03 18:40:56 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:40:56 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:40:57 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:40:57 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:40:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:40:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:57 DTC Client socket (1) | Closed. | 2019-03-03 18:40:57 TransAct Trading | Disconnected. | 2019-03-03 18:40:57 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:40:57 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:41:02 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:41:02 TransAct Trading | Bridge process is not running! | 2019-03-03 18:41:04 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:41:04 DTC Client socket (1) | Creating socket. | 2019-03-03 18:41:04 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:41:04 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:41:05 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:41:05 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:41:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:41:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:41:05 DTC Client socket (1) | Closed. | 2019-03-03 18:41:05 TransAct Trading | Disconnected. | 2019-03-03 18:41:05 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:41:05 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:41:10 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:41:10 TransAct Trading | Bridge process is not running! | 2019-03-03 18:41:12 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:41:12 DTC Client socket (1) | Creating socket. | 2019-03-03 18:41:12 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:41:12 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:41:13 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:41:13 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:41:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:41:13 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:41:13 DTC Client socket (1) | Closed. | 2019-03-03 18:41:13 TransAct Trading | Disconnected. | 2019-03-03 18:41:13 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:41:13 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:41:18 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:41:18 TransAct Trading | Bridge process is not running! | 2019-03-03 18:41:20 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:41:20 DTC Client socket (1) | Creating socket. | 2019-03-03 18:41:20 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:41:20 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:41:21 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:41:21 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:41:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:41:21 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:41:21 DTC Client socket (1) | Closed. | 2019-03-03 18:41:21 TransAct Trading | Disconnected. | 2019-03-03 18:41:21 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:41:21 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:41:26 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:41:26 TransAct Trading | Bridge process is not running! | 2019-03-03 18:41:28 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:41:28 DTC Client socket (1) | Creating socket. | 2019-03-03 18:41:28 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:41:28 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:41:29 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:41:29 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:41:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:41:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:41:29 DTC Client socket (1) | Closed. | 2019-03-03 18:41:29 TransAct Trading | Disconnected. | 2019-03-03 18:41:29 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:41:29 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:41:34 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1900. Current folder: C:\SierraChart\Transact | 2019-03-03 18:41:34 TransAct Trading | Bridge process is not running! | 2019-03-03 18:41:36 TransAct Trading | Connecting to the server 127.0.0.1. Port 1900 | 2019-03-03 18:41:36 DTC Client socket (1) | Creating socket. | 2019-03-03 18:41:36 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:41:36 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:41:37 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:41:37 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:41:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:41:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:41:37 DTC Client socket (1) | Closed. | 2019-03-03 18:41:37 TransAct Trading | Disconnected. | 2019-03-03 18:41:37 Will reconnect to the server in 35.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:41:37 File >> Disconnect selected. | 2019-03-03 18:42:01 TransAct Trading | Disconnected. | 2019-03-03 18:42:01 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:42:02 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1900. Current folder: C:\SierraChart\Transact | 2019-03-03 18:42:02 TransAct Trading | Bridge process is not running! | 2019-03-03 18:42:04 TransAct Trading | Connecting to the server 127.0.0.1. Port 1900 | 2019-03-03 18:42:04 DTC Client socket (1) | Creating socket. | 2019-03-03 18:42:04 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:42:04 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:42:05 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:42:05 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:42:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:42:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:42:05 DTC Client socket (1) | Closed. | 2019-03-03 18:42:05 TransAct Trading | Disconnected. | 2019-03-03 18:42:05 Will reconnect to the server in 40.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:42:05 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:42:45 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:42:45 TransAct Trading | Bridge process is not running! | 2019-03-03 18:42:47 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:42:47 DTC Client socket (1) | Creating socket. | 2019-03-03 18:42:47 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:42:47 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:42:48 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:42:48 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:42:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:42:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:42:48 DTC Client socket (1) | Closed. | 2019-03-03 18:42:48 TransAct Trading | Disconnected. | 2019-03-03 18:42:48 Will reconnect to the server in 40.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:42:48 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:43:28 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:43:28 TransAct Trading | Bridge process is not running! | 2019-03-03 18:43:30 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:43:30 DTC Client socket (1) | Creating socket. | 2019-03-03 18:43:30 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:43:30 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:43:31 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:43:31 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:43:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:43:31 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:43:31 DTC Client socket (1) | Closed. | 2019-03-03 18:43:31 TransAct Trading | Disconnected. | 2019-03-03 18:43:31 Will reconnect to the server in 45.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:43:31 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:44:16 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:44:16 TransAct Trading | Bridge process is not running! | 2019-03-03 18:44:18 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:44:18 DTC Client socket (1) | Creating socket. | 2019-03-03 18:44:18 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:44:18 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:44:19 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:44:19 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:44:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:44:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:44:19 DTC Client socket (1) | Closed. | 2019-03-03 18:44:19 TransAct Trading | Disconnected. | 2019-03-03 18:44:19 Will reconnect to the server in 45.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:44:19 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:45:04 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:45:04 TransAct Trading | Bridge process is not running! | 2019-03-03 18:45:06 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:45:06 DTC Client socket (1) | Creating socket. | 2019-03-03 18:45:06 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:45:06 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:45:07 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:45:07 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:45:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:45:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:45:07 DTC Client socket (1) | Closed. | 2019-03-03 18:45:07 TransAct Trading | Disconnected. | 2019-03-03 18:45:07 Will reconnect to the server in 50.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:45:07 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:45:57 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:45:57 TransAct Trading | Bridge process is not running! | 2019-03-03 18:45:59 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:45:59 DTC Client socket (1) | Creating socket. | 2019-03-03 18:45:59 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:45:59 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:46:00 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 18:46:00 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 18:46:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:46:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:46:00 DTC Client socket (1) | Closed. | 2019-03-03 18:46:00 TransAct Trading | Disconnected. | 2019-03-03 18:46:00 Will reconnect to the server in 50.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:46:00 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:46:50 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:46:50 TransAct Trading | Bridge process is not running! | 2019-03-03 18:46:52 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:46:53 DTC Client socket (2) | Creating socket. | 2019-03-03 18:46:53 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:46:53 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:46:54 * DTC Client socket (2) | Max send buffers used during socket life: 1 | 2019-03-03 18:46:54 DTC Client socket (2) | Signaling to core to close socket | 2019-03-03 18:46:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:46:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:46:54 DTC Client socket (2) | Closed. | 2019-03-03 18:46:54 TransAct Trading | Disconnected. | 2019-03-03 18:46:54 Will reconnect to the server in 55.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:46:54 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 18:47:49 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 18:47:49 TransAct Trading | Bridge process is not running! | 2019-03-03 18:47:51 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 18:47:51 DTC Client socket (2) | Creating socket. | 2019-03-03 18:47:51 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-03-03 18:47:51 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 18:47:52 * DTC Client socket (2) | Max send buffers used during socket life: 1 | 2019-03-03 18:47:52 DTC Client socket (2) | Signaling to core to close socket | 2019-03-03 18:47:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 18:47:52 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:47:52 DTC Client socket (2) | Closed. | 2019-03-03 18:47:52 TransAct Trading | Disconnected. | 2019-03-03 18:47:52 Will reconnect to the server in 55.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 18:47:52 File >> Disconnect selected. | 2019-03-03 18:48:01 TransAct Trading | Disconnected. | 2019-03-03 18:48:01 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 19:38:59 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 19:38:59 TransAct Trading | Bridge process is not running! | 2019-03-03 19:39:01 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 19:39:01 DTC Client socket (1) | Creating socket. | 2019-03-03 19:39:01 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 19:39:01 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 19:39:02 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 19:39:02 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 19:39:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 19:39:02 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 19:39:02 DTC Client socket (1) | Closed. | 2019-03-03 19:39:02 TransAct Trading | Disconnected. | 2019-03-03 19:39:02 Will reconnect to the server in 60.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 19:39:02 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 19:39:36 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 19:39:36 TransAct Trading | Bridge process is not running! | 2019-03-03 19:39:38 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 19:39:38 DTC Client socket (1) | Creating socket. | 2019-03-03 19:39:38 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 19:39:38 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 19:39:39 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 19:39:39 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 19:39:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 19:39:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 19:39:39 DTC Client socket (1) | Closed. | 2019-03-03 19:39:39 TransAct Trading | Disconnected. | 2019-03-03 19:39:39 Will reconnect to the server in 60.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 19:39:39 Requested login tokens. | 2019-03-03 19:39:44 HTTPS www.sierrachart.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-03-03 19:39:44 HTTPS www.sierrachart.com:443 (1) | Connecting to IP: 46.4.97.203. | 2019-03-03 19:39:44 Received 8 login tokens. | 2019-03-03 19:39:44 HTTPS www.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2019-03-03 19:39:49 HTTPS www.sierrachart.com:443 (1) | Max send buffers used during socket life: 2 | 2019-03-03 19:39:49 HTTPS www.sierrachart.com:443 (1) | Signaling to core to close socket | 2019-03-03 19:39:49 HTTPS www.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-03-03 19:39:49 HTTPS www.sierrachart.com:443 (1) | Closed. | 2019-03-03 19:39:49 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 19:40:39 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 19:40:39 TransAct Trading | Bridge process is not running! | 2019-03-03 19:40:41 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 19:40:41 DTC Client socket (1) | Creating socket. | 2019-03-03 19:40:41 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 19:40:41 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 19:40:42 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 19:40:42 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 19:40:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 19:40:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 19:40:42 DTC Client socket (1) | Closed. | 2019-03-03 19:40:42 TransAct Trading | Disconnected. | 2019-03-03 19:40:42 Will reconnect to the server in 65.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 19:40:42 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2019-03-03 19:41:47 Created process C:\SierraChart\Transact\TransactToSierraBridge.exe. Parameters: /Port:1869. Current folder: C:\SierraChart\Transact | 2019-03-03 19:41:47 TransAct Trading | Bridge process is not running! | 2019-03-03 19:41:49 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2019-03-03 19:41:49 DTC Client socket (1) | Creating socket. | 2019-03-03 19:41:49 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-03-03 19:41:49 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-03 19:41:50 * DTC Client socket (1) | Max send buffers used during socket life: 1 | 2019-03-03 19:41:50 DTC Client socket (1) | Signaling to core to close socket | 2019-03-03 19:41:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-03 19:41:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 19:41:50 DTC Client socket (1) | Closed. | 2019-03-03 19:41:50 TransAct Trading | Disconnected. | 2019-03-03 19:41:50 Will reconnect to the server in 65.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-03 19:41:50 |
| [2019-03-04 00:55:03] |
Transact support will need to help you with this. This is a problem with their bridge program . We simply cannot help with this at all. If they cannot resolve it let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-04 02:08:43
