Date/Time: Mon, 27 Jan 2025 19:32:02 +0000
Interactive Brokers CFD Trading data doesn’t load
View Count: 836
[2019-03-03 19:28:12] |
User565999 - Posts: 9 |
Hi Team, in newer sierra versions my trading chart don’t come up and real time data don’t load. I tested several versions and OS. Please take a look. v 1776 OK v 1837 OK v 1875 doesn’t work see error below v 1880 doesn’t work see error below Error shows up when output debugging messagas is enabled: 0=4 | 1=2 | 2=200014 | 3=2127 | 4=CFD historical data is not provided; please submit a historical data request on the underlying stock: SPY@ARCA Thank you very much |
Private File Private File Attachment Deleted. |
[2019-03-03 20:58:11] |
There has been a change with CFD symbols and here is the documentation you now need to follow: Interactive Brokers Symbols: Accessing Market Data for CFD Symbols Let us know if you need further help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
