Date/Time: Mon, 17 Mar 2025 11:32:02 +0000
Automatic Rollover - Date vs Volume behavior
View Count: 2033
[2019-03-03 05:55:22]
HAB-User115006 - Posts: 38
The symbol is set to "Automatic Rollover Futures symbol" in Chart >> Chart Settings menu
Also a date-based rollover rule is defined for the symbol in Global Settings >> Symbol Settings
Also 'Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume' is set in Global Settings >> General Settings >> General 4
1. This should automatically rollover the symbol when DATE conditions are met, correct?
2. If Volume conditions are met BEFORE the above date conditions, will there be an automatic rollover based on Volume or just an indication but NO automatic rollover?
3. If there is an indication, will the Date rollover criteria also apply and automatically rollover after the Volume indication has been set?
4. Where would I see this indication and how do I clear it?
[2019-03-04 00:22:07]
Refer to the documentation here:
Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu)
What causes the rollover is documented. It is not really automatic. The chart has to be reloaded for that to happen.
Date Time Of Last Edit: 2019-03-04 00:31:09
[2022-08-17 16:56:46]
user08187 - Posts: 15
Hi
I updated chart to "Continuous Futures Contract - Volume Based Rollover, Back Adjusted". Even now, for Monthly chart, it's not showing data before August 2019.
Log:
Software version: 2424 64-bit | 2022-08-17 11:36:22.674
Primary Thread ID: 908 | 2022-08-17 11:36:22.674
Usage end date: 2022-09-15 | 2022-08-17 11:36:22.674
Enabled for: Advanced Features 2. | 2022-08-17 11:36:22.674
Enabled for: Sierra Chart Historical Data Service. | 2022-08-17 11:36:22.674
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-08-17 11:36:22.674
Enabled for: Delayed Denali Exchange Data Feed. | 2022-08-17 11:36:22.674
Enabled for exchange2: CME | 2022-08-17 11:36:22.674
Enabled for exchange2: fairx_exchange.data | 2022-08-17 11:36:22.674
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-08-17 11:36:22.674
Current selected Data/Trading service: SC Data - All Services | 2022-08-17 11:36:22.674
Custom symbol settings values: enabled | 2022-08-17 11:36:22.674
Chart Update Interval: 500 | 2022-08-17 11:36:22.674
Intraday Data Storage Time Unit: 0 | 2022-08-17 11:36:22.674
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-08-17 11:36:22.674
2022-08-17 16:36:22 Local computer time in UTC | 2022-08-17 11:36:22.674
2022-08-17 11:36:22 Local computer time in SC Time Zone | 2022-08-17 11:36:22.674
2022-08-17 13:42:16 Server time in UTC | 2022-08-17 11:36:22.674
Local computer UTC time and Server UTC time difference: 2 seconds. | 2022-08-17 11:36:22.674
Program path: D:\ | 2022-08-17 11:36:22.674
Data Files path: D:\Data\ | 2022-08-17 11:36:22.674
OS Version Number: 10.0 | 2022-08-17 11:36:22.674
Locale Setting: C | 2022-08-17 11:36:22.674
DLLs: UserContributedStudies_64.dll | 2022-08-17 11:36:22.674
Allowed protected custom studies: | 2022-08-17 11:36:22.674
Crash reporter started: true | 2022-08-17 11:36:22.674
SC Data - All Services | Connected to server complete. | 2022-08-17 11:36:26.625
Triggering next historical data download in queue. | 2022-08-17 11:36:26.625
No download requests in the queue to start downloads for. | 2022-08-17 11:36:26.625
Mapping MESU22-CME to MESU22. Service code: cme | 2022-08-17 11:36:27.053
Using symbol data fast lookup vector | 2022-08-17 11:36:27.053
SC Data - All Services | Starting real-time market data updates for: MESU22-CME (MESU22). ID: 1 Service code: cme | 2022-08-17 11:36:27.053
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2022-08-17 11:36:27.053
SC Data - All Services | Requesting security definition data for: MESU22-CME (MESU22). ID: 1 | 2022-08-17 11:36:27.053
DTC Client socket (2) | Creating socket. | 2022-08-17 11:36:27.073
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-08-17 11:36:27.073
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2022-08-17 11:36:27.073
SC Data - All Services | Network connection to server complete. | 2022-08-17 11:36:30.691
SC Data - All Services | Starting socket receive thread. | 2022-08-17 11:36:30.691
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-17 11:36:30.691
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-17 11:36:30.975
SC Data - All Services | Sending logon request message. | 2022-08-17 11:36:30.975
SC Data - All Services | Received logon response. | 2022-08-17 11:36:31.786
SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-17 11:36:31.786
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-17 11:36:31.786
SC Data - All Services | Successfully connected. | 2022-08-17 11:36:31.786
SC Data - All Services | Trading is not supported. | 2022-08-17 11:36:31.786
SC Data - All Services | Restarting real-time data updates for symbol: MESU22-CME -> MESU22 | 2022-08-17 11:36:31.786
SC Data - All Services | Received security definition for symbol MESU22-CME | 2022-08-17 11:36:31.970
MESU22-CME Daily #2 | Reloading chart. | 2022-08-17 11:36:50.452
MESU22-CME [CBV][M] Daily #2 | Reloading chart. | 2022-08-17 11:37:18.614
MESU22-CME [CBV][M] Monthly #2 | Reloading chart. | 2022-08-17 11:37:31.790
ESU22-CME [CBV][M] Monthly #2 | Reloading chart. | 2022-08-17 11:38:02.687
ESU22-CME [CBV][M] Monthly #2 | Performing continuous chart historical Daily data download for symbol ESU22-CME starting at last date in file. | 2022-08-17 11:38:02.754
Added historical Daily data request for ESU22-CME to the queue. | 2022-08-17 11:38:02.754
Triggering next historical data download in queue. | 2022-08-17 11:38:02.754
ESU22-CME [CBV][M] Monthly #2 | Waiting for historical downloads to complete with the IDs: 9, | 2022-08-17 11:38:02.877
Mapping ESU22-CME to ESU22. Service code: cme | 2022-08-17 11:38:02.917
HD Request # 9 | Downloading Historical Daily chart data for ESU22-CME. Starting date: 2022-08-11. Service: scdataallservices | 2022-08-17 11:38:02.918
HD Request # 9 | Requesting historical Daily data for ESU22 starting at 2022-08-10. SC External HD service. | 2022-08-17 11:38:03.797
HD Request # 9 | Receiving historical Daily data for ESU22-CME starting at 2022-08-11. | 2022-08-17 11:38:04.150
HD Request # 9 | Writing historical Daily data to the file ESU22-CME.dly. | 2022-08-17 11:38:04.150
HD Request # 9 | Bytes received: 309 | 2022-08-17 11:38:04.155
HD Request # 9 | Received 5 Daily data records from 2022-08-11 00:00:00 to 2022-08-16 00:00:00 (6.0 days) and wrote 4 records for ESU22-CME | 2022-08-17 11:38:04.155
HD Request # 9 | Completion time: 2s. | 2022-08-17 11:38:04.155
HD Request # 9 | Daily data download complete for ESU22-CME. Unique request ID: 9 | 2022-08-17 11:38:04.155
Removing historical data download ID 9. | 2022-08-17 11:38:04.155
Triggering next historical data download in queue. | 2022-08-17 11:38:04.156
No download requests in the queue to start downloads for. | 2022-08-17 11:38:04.156
ESU22-CME [CBV][M] Monthly #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-08-17 11:38:04.182
ESU22-CME [CBV][M] Monthly #2 | Reloading chart. | 2022-08-17 11:38:04.184
ESU22-CME [CBV][M] Monthly #2 | Reloading chart. | 2022-08-17 11:38:04.685
SC Data - All Services | Starting real-time market data updates for: ESU22-CME (ESU22). ID: 2 Service code: cme | 2022-08-17 11:38:05.180
SC Data - All Services | Requesting security definition data for: ESU22-CME (ESU22). ID: 2 | 2022-08-17 11:38:05.180
SC Data - All Services | Received security definition for symbol ESU22-CME | 2022-08-17 11:38:05.386
imageScreenshot 2022-08-17 183910.jpg / V - Attached On 2022-08-17 16:55:31 UTC - Size: 102.62 KB - 125 views
[2022-08-17 17:12:23]
John - SC Support - Posts: 38678
First, what is the setting for Chart >> Chart Settings >> Data Limiting >> Chart Data Type set to?
Second, what is the Chart >> Chart Settings >> Data Limiting >> Days to Load for Historical Chart Data Type set to?
[2022-08-17 17:37:52]
Hi
I updated "Day to Load" to 4380 in one chart, and it's working fine.
Thanks for your help.
