Date/Time: Mon, 27 Jan 2025 16:46:03 +0000
data fees
View Count: 621
[2019-03-02 20:40:54] |
Yeager - Posts: 128 |
Hi, I only trade oil. CL on NYMEX. Do I need the xchange Data Feed: 100 Real-Time Symbols (1st Connection). AND my NYMEX data? Or can I just pay for the NYMEX data feed? Thanks Tim |
[2019-03-02 22:38:38] |
You do need the real-time connection but you can change it to 20 symbols to reduce the cost to 25 USD per month. You can do this here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#DataConnections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
